FULLY built 92 eg hatch idle dip thunk.. please help
So first off I searched and found pretty much nothing on my topic so I signed up here and see if this community can help!
So I recently bought a 92 hatch fully build 700+ hp.. I know what I'm doing with it and the what not's but long story short.
-recently I just noticed a thunk or knock when the idle dips... on this hatch it seems to always dip when I left off the gas in a neutral position (in neutral or push in the clutch)
- The dip isn't what bothers me, its the knock or thunk sound it makes. I'm on 17 LBS to learn how to drive the car not 35+ on what the car is tuned for. I opened the hood played with the throttle a little and could not hear the sound. It's only in the car when I here it and it does this every time.
-So even idling.. lets say I tap the gas and it revs to 3k. When it falls down it goes to about 600rpm and levels it way up to 1100. BUT on its way down the thunk or knock happens at about 1300.. and it sounds like its comming from the front of the car.
- To me it almost sounds like something might be vibrating or hitting something but for it to happen every time at the same rpm has got me wondering what it is?
So this is my intro post to the forums owned the car for about a week now and drivin it 400 miles. only really boosted it about 5 times tbh.
All help is appreciated. Thanks!
Re: FULLY built 92 eg hatch idle dip thunk.. please help
We never found it 100%. the map was reading high on idle thus dumping lots more fuel then needed. so I suspect that had something to do with it doesn't do that any more but will do it every now and then on a cold start morning.
So being tuned for a high boost like that with fuel and what not then running lower boost but still getting the same large amount of afr wont effect how the motor runs? I would have thought unless it is retuned for the lower psi it would be dumping alot more fuel than needed for the lower boost and cause it to run rich or something. My logic is wrong sorry for the mis informed idea.
Makes since thanks for the explanation.
This is just another reason i don't buy other peoples boosted or swapped setups because you never really know what its been through or if it was done correctly. Hope the op gets it figured out though.
blu3fan
07-25-2012 12:50 PM
Prudz_lude
10-24-2007 10:39 AM
blkhatch92
02-06-2006 09:01 PM
