99 DX no start after removing dizzy. worked fine before.
Old 05-09-2013, 02:15 PM
B_Swapped93's Avatar
Default 99 DX no start after removing dizzy. worked fine before.
99DX W/y7.
no codes fuel pump primes battery is good have tried starting it when jumped won't even crank. I'm thinking lose/bad ground ? starter doesn't click you can turn the key all you want....nothing. all I did was take the distributer off never touched the battery or anything else it worked fine before. Could use some input
Old 05-09-2013, 02:51 PM
nealnanoHX's Avatar
Default Re: 99 DX no start after removing dizzy. worked fine before.
Try tapping the stater with a hammer while someone turns the key.
Old 05-09-2013, 03:24 PM
EL Vap133's Avatar
Is the rotor still in place on the dizzy?
Old 05-09-2013, 03:29 PM
Yes, I tried taking the cap off snapped one of the 3 bolts so it's stuck on there pretty good stopped after that.
starter has never acted up gave it a hit or two. the lights and all come on just nothing when I turn the key aside from the pump priming. it's not cranking/trying to turn over
Old 05-09-2013, 08:17 PM
Bump would like to get this thing started as it's dead on my lawn
Old 05-09-2013, 08:38 PM
ej7attack's Avatar
was the battery hooked up still when you pulled the dist connector? maybe a fuse.
Old 05-09-2013, 08:49 PM
yes but I've done this several times with my GS-R never hurt it will have a look at the fuses tomorrow never though of that may have shorted(blown fuse) something would seem odd but worth a check.
Old 05-09-2013, 09:00 PM
Former User's Avatar
Did you disconnect the G3 transmission ground?
Have you checked both starter wires (motor and solenoid)?
Old 05-09-2013, 09:04 PM
bufalo123's Avatar
check the fuses in the engine bay
Old 05-10-2013, 06:24 PM
never touched anything other than the cap it's self will check fuses tomorrow my integra decided to not start also now anyone know if the dx pump will work on it it's a 94 GSR
Hondacrf
06-16-2017 04:13 AM
ohcrapgorillas
06-02-2014 01:20 PM
xander1100
10-18-2009 07:56 PM
guy_from_nerk
09-25-2009 02:47 PM
junya16
03-01-2003 07:30 PM
Quick Reply: 99 DX no start after removing dizzy. worked fine before.
