99 Si or Clone?
99 Si or Clone?
I am obviously new here but I wanted other's opinions on whether or not m civic is a real SI. Before i purchased it I checked all the vins and they match, EM1 all around but the car lacked certain SI features. It had an engine swap to a b20b with gsr tranny and short shifter but it has a small ac compressor. The ac compressor for the b series from what I have seen are much larger. The SI badge on back was removed supposedly so as to not advertise that its an SI to minimize attention (thats what last owner said). It does have the SI spoiler but was painted black for some odd reason (it has some chips and the blue shows underneath. The big thing that caught my attention though is that it isnt all disc brakes, the rear are drums. Also the doors are not original to the car. So was i cheated or is everything ok? Ill try and post some pictures.
Re: 99 Si or Clone?
Re: 99 Si or Clone?
Yes just like the GS-R/ITR^^
I'm sorry but that really looks bad...no way that is/was a Si/SiR no ABS you missed that. Are those even the correct mounts ?
Re: 99 Si or Clone?
I decided now to get a carfax on the vin, yea i should have checked before but ill see what I find. Also how hard would it be to change all the vins. the engine bay seems like a challenge and the one by windshield doesnt look tampered.
Re: 99 Si or Clone?
while it says clean title it will say that if the PO didn't report it afaik im not sure what's going on with that car
Re: 99 Si or Clone?
Run the carfax, if it's not a theft recovery or salvaged title, someone picked specific parts off it, then sold it.
99 should have VIN stickers on every panel, fenders, trunk, hood, doors. If these parts don't have matching VIN stickers, than it tells you it was put back together, either from theft or accident.
Re: 99 Si or Clone?
I got the carfax which says guaranteed no theft, salvage, fire, hail, etc. It had 5 owners, im the 5th. 1st owner had it for 9 years , 2 for 4 years, 3 for 11 months, 4 for 1 month and now me.
Re: 99 Si or Clone?
I knew a guy that wrecked his old Monte Carlo SS, he had liabilty coverage. So he bought a clean base model shell and swapped vin numbers and all the usable parts over. He later sold the car as an SS. Not saying thats what happened in your case, but i know it happens fairly often
Re: 99 Si or Clone?
There's something hinky with the "clean" title of the car then. Unreported damage, vandalism or one of the previous owners stripped parts and sold it to an unknowing buyer as a clean Si, which it is definitely not.
It is what it is at this point. Rear disc conversion typically can be had for under $200 here in So.Cali. It's plug and play, remove old drum, bolt up replacement rear disc, replace e brake cables with EM1 cables
Re: 99 Si or Clone?
I dont know if tranny is original. I doubt it though. Also i just remembered something that made me second guess its authenticity. I tried to replace rotors and pads with some i bought online but the rotors were much bigger than the ones it had on and I had to get smaller rotors from autozone and return the other ones
Also this car is just so I can drive to the police academy until I graduate and start working after which ill be able to afford a newer everyday car and this one will be a toy to play with and add boost and other goodies
Re: 99 Si or Clone?
If it's the original trans it will have a green VIN tag riveted on the bell housing right next the where the engine code B20 is.
Sounds like they took the complete brake system and swapped it with a Dx/Lx, which has smaller front discs, 9.5" I believe versus the EM1 10.2" if I remember correctly and rear drum brakes.
Re: 99 Si or Clone?
O well thanks everyone for the help. I leave it as is and bring it up to original specs after i graduate. in the meantime as long as it runs fine for the next 6 months i'll be happy.
