extra connector??
extra connector??
today, i removed driver side under dash panel to fix something,
and i fount long wireharness that was taped around. i removed the tape and found bunch of connector fittings.. can someone tell me what these are for?..
i bought this car used, so don't know much about the history of previous...
this is 1996 civic dx hatch
Re: extra connector??
hm...
but my vin number show 2HGEJ63XXXXXXX
which means it was originally stick shift. cuz i know 7th digit with "3" is for stick, and "4"
is for auto.
could it be something else??
is for auto.
but this car did front conversion 96 to 00 civic with power windows, and it looked like power mirror too. but don't have the switch for it nor cant find connector for it..
i'll take more pics of it shortly
They are your service connectors. The one with two wires is the one you jumper to read the check engine light. The others are for OBD scanners and other diagnostics I am guessing.
And none of the connectors looks like the OBD2 data link connector (DLC).
here are more pics and found one more connector ...
car starts up, drives fine.. no check engine light
hm, hope nothing serious...
Looks like you were right. The large connector is C433 (largest connector in your picture). The 00 Civic wire harness must be from a Civic with an automatic transmission.
so i guess the previous owner used auto wire harness to connect power window conversion i guess?.. thanks a lot guys for info...
so these other connectors are dummy as well then ?...
This 4-wire connector is C435 - Gear position light and park pin switch (A/T related).
Second picture in post #9:
This is 2-wire connector C434 - shift lock solenoid (A/T related).
Last two pictures in post #9:
This is 8-wire connector C431 - interlock control unit (A/T related).
magicmike23
05-23-2007 10:49 AM
DetroitPOScivic
06-29-2004 05:39 PM
