5 speed conversion
5 speed conversion
I got a 93 Del slo, automatic(yes I know.) I wanna change it to 5 speed. I'm not sure if any shifter will fit. Like an EK or Teg. I'm leaning on going to a b20 swap since its easier to find than a b16 or GSR . Anyone know which shifter and linkage will work ?
Re: 5 speed conversion
del sol shift linkage is special (specific to del sol only) you cannot use a eg/ek/or dc linkages.
if you install a b series get a 93 97 del sol (VTEC model, b16a3) linkages.
can anyone chime in on the passengers side trans mount. i see alot of auto to 5spd conversions it appears the engine/trans assy sits high on the passengers side.. do you have to drill a new hole for the trans mount bolt or does it require cutting the motor mount pocket Off and re weld a 5spd style pocket in?
Seagull Management
