TPS issue*
TPS issue*
im having an issue with my tps voltage. I have an omni power 68mm throttle body with aftermarket tps. Im using a p28 chipped ecu with my obd2 engine harness that came factory from my coupe.
I back probed the sensor and got my .5v at closed throttle and only 3.4v at wide open throttle, at the max adjustment. I also have CEL that flashes 7 times which is the tps sensor. Im not sure where to go from here and i need some assistance.
Re: TPS issue*
i changed it once already and it still codes. i deleted my o2 and knock sensor on this ecu. I have an obd2 ecu i can try. and i also bought another one off inline four just in case. i may try a oem throttle too if i can find one.
Re: TPS issue*
Haven't heard of this issue with Omni Tb's before or any for that matter. when you say disable what are we talking s300 RTP or chrome ?
Re: TPS issue*
Does the code come on right away or after you start and run the vehicle?
Generally you dont get a TPS CEL unless the sensor faults high or low (0 volts or 5 volts)
Re: TPS issue*
.5 closed and 3.5 open should be fine...in Crome you cant really setup the 0 and 100% points quite as nicely as you can with Hondata, Neptune or eCtune...it may just be this.
1000_miles
12-20-2006 03:28 PM
