idling and driving problems on 99 ex
I just bought a 99 civic ex coupe about a week ago, and just to keep up on matainence I decided to do a tune up on it. Well it did not turn out so good. This is what I did. Fram air filter, duetch fuel filter, denso iridium spark plugs, royal purple 5w30 oil, mobil 1 oil filter, and royal purple in tranny 10w30. Well after I got done installing all of this I started it up and right away it threw a check light. It was idling at about 1100 to 1200 rpms and black snoke was coming out the back. The first thing I thought is it is running rich. So I decided to drive it to work and back to see if the problem would clear up. Well it did for a little while and then went back to running rich. When I am driving it, it seems to chug a little its kinda jumpy, and on take off the rpms drop and it seems like it wants to die. I took it to autozone and they hooked up their little scanner and it said the MAP sensor sensed high voltage or something. I need help really bad could it be a vaccuum hose or the MAP sensor itself or misgapped plugs by the way we did gap them before putting them in. Any help would be appreciated thanks.
Re: idling and driving problems on 99 ex (slickciv)
by the way this is the code that came up thought this might help and does any one know what it means- P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
t-town_ep
09-19-2007 10:26 PM
slickciv
01-30-2005 09:39 AM
