Need Help!! Civic '97 Problem!
A couple weeks ago my brother's '97 Civic DX started making really loud noises when it idles and when you accelerate. It sounds something like a remote control car (seriously).
When we pop the hood, we can see where the problem is, but we have no idea how to fix it. Towards the front right of the engine, there is either a fan or a pulley that spins with a small belt on it. Its extremely loud and has a somewhat metal on metal sound.
We're planning on taking the car in to be looked at, but I was wondering if anyone knew what it might be. Not being technical, if the mechanic said anything and ripped me off I would probably be a sucker for it.
I'm wondering if the thing just needs to be greased or something. Any help would be much appreciated.
Thanks,
Michael
Thanks,
Michael
1 Post
Re: Need Help!! Civic '97 Problem! (trudat)
If it's definitely coming from that pump, then yes, it's probably the p/s. But, I had a friend who's water pump was making a loud *** screaching noise (it sounded of metal on metal, too). Just my input
Re: Need Help!! Civic '97 Problem! (hatchling37)
remove the ps belt if check if you still have noise, then remove a/c belt and check if you still have noise, then remove alternator belt and check if you still have noise, If you still have it it's the timing belt tensioner
Dx's had manual racks. If it is the pulley way down, its the a/c fan clutch pulley.
If you trace the rubber hoses, it goes forward toward a radiator looking piece, this is the condensor.
Genie.S
06-27-2016 01:12 PM
