VTEC and Speedometer not working.
I recently had an exedy clutch and flywheel installed in my car and now my VTEC and my speedometer doesn't work. I read in the forum that it could be caused by low oil pressure so I immediately did an oil change on the car and it's still experiencing the same thing. Now my check engine came on.
Does anyone know what the problem could be? Has anyone experienced this same problem?
Re: VTEC and Speedometer not working. (RotiEatter)
I'm new to all this and don't want to sound too dumb. What is the VSS and where is it located?
Re: VTEC and Speedometer not working. (gsr984dr)
VSS is vehicle speed sensor it its straight down from the throttle body on top of transmission right above where the axles go in.
Chris
Chris
Re: (AllmtrSlut)
I dont know how to check for codes. I checked and made sure all the sensors (plugs) were connected all the way.
This is a 00 Si that is having the problem. Just so you all know.
Thanks.
Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotiEatter »</TD></TR><TR><TD CLASS="quote">If your speedometer isn't working VTEC won't work either. Make sure your VSS is plugged in, they may have forgot to plug it back in.</TD></TR></TABLE>
damn, i never knew that. now i know though
2.2 teg
06-04-2007 09:47 PM
civicseth
16
05-18-2005 08:51 PM
1992, 2000, 95, b18c1, civic, honda, isnt, notworking, sispeedometer, spedometer, speedometer, vtec, vtech, work, working
