99-00 Civic OEM Fog install,...I need help wiring them to light up when just parking lights are on,
I finally got time to install my Fogs this weekend, But came across a small problem.
The fog lights only get power when the headlights are turned on.
I'm looking to have them come on before that, When the Parking lights are on...or just by them selves.
Kind of like this.......
This white coupe.....
and/or this
Can anyone send me in the right direction?
Thanks in advance
-Jeff
and/or this
Thanks in advance
-Jeff
Re: 99-00 Civic OEM Fog install,...I need help wiring them to light up when just parking lights are
yeah thats tight, when you find out i'll give ita try too.
Whos white hatch in the pic ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Enrikez »</TD></TR><TR><TD CLASS="quote">yeah thats tight, when you find out i'll give ita try too.
Whos white hatch in the pic ?</TD></TR></TABLE>
https://honda-tech.com/zero...11346
Here you go, After 45 minutes of searching H-T....I found the answer!!!
wire em to fuse box under dash to your parkin lights. or have a seperate switch . most kits come with the oem honda switch thats should go on the dash panel . how did you cut the bumper to put em in i havent did mine yet just curious post some pics
Re: (civicrida3)
This is in a lot of posts but here it is again for civicrida3
http://www.hondaautomotivepart....html
The factory instructions. On page three it says to use a holesaw 40mm to make some holes and then use a utility knife to cut the rest. From what i read most people use the holesaw and then a dremel to get the rest. Followed by a file to clean up the rough edges. That last step is not really neccessary since the fog light trim will cover this area but it makes everything look nice.
drew@tna_auto
410
03-07-2012 12:09 AM
drew@tna_auto
151
01-31-2011 10:30 PM
5_Lug_B
Lighting
09-11-2007 02:20 PM
