99/00 OEM fog light install in a 96
Got my OEM fog lights today...woot!
I have a 96 DX with a 2000 front end. My question is, can I follow the directions for the 99/00 civic? Are all the same factory plugs going to be there, or will I have to do a 'custom' install?
Thanks
Thanks
Re: 99/00 OEM fog light install in a 96 (awdriscol4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by awdriscol4 »</TD></TR><TR><TD CLASS="quote">I have a 96 DX with a 2000 front end. My question is, can I follow the directions for the 99/00 civic? Are all the same factory plugs going to be there, or will I have to do a 'custom' install?</TD></TR></TABLE>
good question, i would also like to know. BUMP
1 Post
i'd say the wire from the cabin to the engine bay for the positive foglight leads is there,and the trigger and feed circuits are in the cabin,but i'd be surprised if all the plugs are the same and it all matched right up.try finding the instructions for 96-98 foglights and compare.
Chris
Chris
Ok, done....and I must say that was the easiest install I've ever done of anything!! Gotta love OEM goodness!!
the 96-98 install is exactly the same as 99-00. The plugs and everything else are the same. Hope this helps anyone else...
Here is a pic...sorry for the quality, it was getting dark...hope to have some good quality pics up soon..
Re: 99/00 OEM fog light install in a 96 (JDMisGOOD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMisGOOD »</TD></TR><TR><TD CLASS="quote">NICE!</TD></TR></TABLE>
Re: 99/00 OEM fog light install in a 96 (chreeno)
Quick question...
can someone please confrim that the bulb for the 99/00 fog lights is a H3....???
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by awdriscol4 »</TD></TR><TR><TD CLASS="quote">Quick question...
Thanks </TD></TR></TABLE>
Yes the fog light bulb is H3 sized bulb.
i had some trouble installing my fogs as welll. i have 99-00 front on a 96-98.
https://honda-tech.com/zerothread?id=1068394
hope this helps
hope this helps
those look really well. mine were not an easy install, damn you ebay..damn you to helllllll. but anyways they look super good. kudos to you man
Re: 99/00 OEM fog light install in a 96 (eg4usdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CTRb18c »</TD></TR><TR><TD CLASS="quote">Yes the fog light bulb is H3 sized bulb.
hope this helps </TD></TR></TABLE>
Thanks for the bulb info......what trouble did you have? was it an OEM fog light kit? I had no problems with the install....
Re: (CTRb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CTRb18c »</TD></TR><TR><TD CLASS="quote">i used the hole saw on one side like the instructions said, then i used a dremel to cut the other hole,which saved alot more time.</TD></TR></TABLE>
For sure thats the easiest way...find the marks on the back side of the bumper and start pilot holes. Then use a 40mm hole saw (I used 1.5" which is pretty close to 40mm) then use a dremel to finish cutting it out. I also used a file to smooth everything out, although you dont really need to since its completely covered anyway.
Here are the instructions I used:
http://www.handaaccessories.co...s.pdf
Hope that helps
Hope that helps
Thanks for the bulb info......what trouble did you have? was it an OEM fog light kit? I had no problems with the install....</TD></TR></TABLE>
they claimed oem but when i opened the box it didnt say for 92-25 oem kit it just said 92 civic fog light kit. we had to cut into the bumper brakets and remove some impact spacers or something it was originally an hour 1/2 job that turned into 71/2 hours. freaking shitttyyyy. they turned out good tho with fabrications.
ebay sucks
ebay sucks
