can someone answer this for me, i am lost
ok here is the deal i got my b16 running finally and it was ok it acts up from idle to 2500 rpms after 2600 it acts like it should so i took off the p28 and put in a p06 same thing took off the obd1 converstion and put in my p2e and it idled just fine and ran good all this time i thought it was a vacuum leak but it is something to do with the ecu could it be my ecu convertion kit? because it acts like i have no fuel or it is not getting enough air or something but once i open the thottle it acts just fine but it is scary because if i am just crusing it want so bog and hesatate all the time but when i open it up it runs fine what could it be?
Re: can someone answer this for me, i am lost (civiclxb16)
I have a b16 running off a obd-1 p28. My motor is obd1 also. My car hesitates between 2000-2600 also. I havent tried running any other ecu. But I have been told that it is the cause.
After 2600, the hestitation is gone, and the car drives fine. Your not the only one.
Get the correct ecu for the car, and it should go away.
Re: can someone answer this for me, i am lost (Redcoupe)
well the engine is obd1 and the car is obd2a there is no dohc ecu made for my engine that is why i went with the chipped p28
cua0
09-14-2005 04:53 AM
