check engine light on EK(gsr swap)
Ok heres the deal. I have a 96 civic hatchback with a 01 gsr swap. I am using a 96-98 civic ex engine harness on the 01 gsr swap. I was using my obd1 p72 ecu and thought the engine light would be clear, but it still poped up. I went over to my friends shop and his computer couldnt read the obd1 p72 for some reason. I had to go home and pick up my obd2 p72. When he checked it again, it worked and basically the second o2 sensor came up and a intake sensor? I knew if I were to use the obd2 ecu the second o2 sensor would come up, but why would the intake sensor come up? I'm thinking of running the second o2 sensor into my ecu but I dont know the pin out and plus need a little help with the intake sensor, dont know where it is exactly and I just remembered there are 2 plugs that arent being used at the time. One plug is located near the TB and the other plug is located near the postive terminal on the battery. Can anyone help me out?
Re: check engine light on EK(gsr swap) (P-Dubb)
thanks for the info, I dont have a IAT sensor on my intake for some reason. The intake elbow is stock gsr and has no holes for the IAT.....what can I do? Theres a plug I noticed thats unplugged near the throtle body. Its a 2 wire black plug with blue insert. Theres also <U>another</U> similar plug by my batter/passenger side shock tower thats not plugged either
EKdriverin703
05-05-2011 07:21 AM
tinypayuk
07-28-2005 02:49 PM
