How to install turbo?
Re: How to install turbo? (RevhardLs25)
If you have to ask, you probably shouldn't be doing it. Just buy a kit and have a professional install it.
No money for a kit? Here's some things you're going to need:
Turbo+manifold(duh)
Intercooler(optional, but optimal)
piping
Fuel pressure regulator
MAP clamp
fuel pump
fuel injectors
Waste gate
Blow off valve
Have everything plumbed for a return line system
about a grand in odds and ends(couplers, ties, lines, etc.)
Figure anywhere from $20-$500 in dyno time(depending on how good the shop is with a dyno, it could take a while, and you're paying for their time)
And don't forget, if you have any problems with your engine now(no matter how insignificant) the turbo will bring them out in a heartbeat. Set some money aside for WHEN (not if) something goes wrong.
A few other things probably that I can't think of off the top of my head. Look up on all that stuff and what it's all for and you will begin to understand.
Turbo+manifold(duh)
piping
MAP clamp
fuel pump
fuel injectors
Waste gate
Blow off valve
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RevhardLs25 »</TD></TR><TR><TD CLASS="quote">I have a 98' Ls motor, and I want to install a factory Greddy turbo.</TD></TR></TABLE>
Could you be a little more specific? I agree with the fact that if you're asking this then you probably shouldnt be doing this at all. Let someone else do it. If you have the kit...then put it on....not much else to it unless you specify your question. GL
Re: How to install turbo? (Revolver)
https://honda-tech.com/zerothread?id=268110
http://www.cse.uconn.edu/~yele....html
I would post alot more links but i doubt ill ever see you on the site again.
Re: How to install turbo? (Luserkid)
lets see
turbo mani to head
turbo to turbo mani
down pipe to turbo setup
charge pipe from intake to one passenger side of intercooler
add ur bov to ur charge pipe
intercooler behind bumper
other intercooler pipe to turbo
wastegate to turbo
wastegate dump tube to air
intake filter to intake side of turbo
run ur lines
install a walbro fuel pump
fuel reg
some decent injectors
some tuning
and ur set sort of.
turbo mani to head
turbo to turbo mani
wastegate to turbo
run ur lines
fuel reg
some tuning
and ur set sort of.
hatch808
06-05-2003 06:51 PM
