Oil light lighting up on mini me...
Heya,
Just finished redoing wiring of my d16y7 / d16y8 mini me. Now the car is flashing the oil light at me... Oil is ok in it.
The car is slow on take off too, any ideas ?
Oh and my second O2 sensor is not plugged and its coding 65... Is that a big problem ??
Re: Oil light lighting up on mini me... (HondaSE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaSE »</TD></TR><TR><TD CLASS="quote">
Hows the oil presure? I wouldn't run it until I found out.
Risky Business
Oh and my second O2 sensor is not plugged and its coding 65... Is that a big problem ??</TD></TR></TABLE>
Uh, yeah. Plug it in.
Re: Oil light lighting up on mini me... (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">Uh, yeah. Plug it in.</TD></TR></TABLE>
Maybe the same for the oil presure sensor?
if the light on on the time? if it is... its probably not hooked up. if its blinking or coming on at idle, then you probably got some issues.
[QUOTE=HondaSE
The car is slow on take off [/QUOTE]
Probably because you have a whopping 90HP under that beast . Watch out everyone... Dont race this true ricer
Re: Oil light lighting up on mini me... (HondaHemp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaHemp »</TD></TR><TR><TD CLASS="quote">Probably because you have a whopping 90HP under that beast . Watch out everyone... Dont race this true ricer </TD></TR></TABLE>
He's a ricer?
He's a ricer?
Re: Oil light lighting up on mini me... (Hatch It)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch It »</TD></TR><TR><TD CLASS="quote">
He's a ricer? </TD></TR></TABLE>
Serious...
Check your wiring again...reset ecu...
Serious...
Re: Oil light lighting up on mini me... (OoBryan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OoBryan »</TD></TR><TR><TD CLASS="quote">Serious...
Check your wiring again...reset ecu...</TD></TR></TABLE>
Yes exactly try that, it made my oil light go away
Well thanks for tips gonna try to reset ecu, plugs seem all ok to me. Gonna flush the oil tomorrow to make sure...
Need to get me a cat for the second o2 sensor, the thing is just hanging there.
check your oil pressur with a real gauge. Is the oil pan dented.
If the oil pressure sensor is not pluged up it the light will not come on...
You only have to have about 7psi for the light to go off
Re: Oil light lighting up on mini me... (b18ccivics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18ccivics »</TD></TR><TR><TD CLASS="quote">check your oil pressur with a real gauge. Is the oil pan dented.
You only have to have about 7psi for the light to go off </TD></TR></TABLE>
oh yeah, i just remembered that when its not connected the light stays OFF.
Actually when working properly he should have between 120-130HP.
What makes him a ricer?
BTW, the oil sensor works by closing the line to ground, so if the wire from the sensor has a bad place in the covering on it then it may be shorting to the chassis and causing a false oil warning.
You most definetly should hook an oil pressure gauge up to it to make sure.
Re: Oil light lighting up on mini me... (Hurricane)
Actually hoping for a bit more hp, got comp cam 59100 (didn't want to change the springs / lifters) and dc sports headers, gonna have the whole exhaust redone too, need to get that second o2 sensor installed. Also got the head shaved I believe it was max shave possible, 8mm , correct me if I'm wrong though.
So the oil problem seems to be gone, I flushed oil and reset ecu. No more light is on . Thanks for help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hurricane »</TD></TR><TR><TD CLASS="quote">
You most definetly should hook an oil pressure gauge up to it to make sure.</TD></TR></TABLE>
i wouldn't count on 120-130HP on the dyno from a mini-me 90hp is way more realistic
lemongreenhatch
10
08-15-2004 06:47 AM
