Knuckle installation help
I have a 94 EG cx I am doing the integra front brake swap, and yesterday I had my new Lower balljoint pressed in and I used a 2001 integra GSR balljoint. Right now I try to install it , everything is fine except that the knuckle would not connect with the upper control arm. The whole knuckle is tilting from the inside...what should I do? If was fine few days ago when I try em on. Thanks...please help.
I was trying to push it back with the knuckle there, should I take off the knuckle and do it or...? I think I was pulling on the knuckle when I tried to take it off and possibly pull the axle too. Thanks.
Re: (BANNED_ID)
check and make sure its not out of the tranny first... if its still seated in the tranny i would take the knuckle off and then mess with it... by the sound of it you have been messing with it alot so its prob gonna take a little work to get it back in... i think it would be easier with the knuckle off... once you get it back in place you should be all set
* B A N N E D *
1 Post
Re: (BANNED_ID)
remember that with your car, the WHEEL and TIRE sit perpendicular to the ground, however the angle of the knuckle may not look straight up and down, the bearing is wehn you get it in right.
This axle ^%#$ is really diffcult to deal with, I had to take it to a mechanic to open up the boot and putting everything back together, then when I got back home and putting everything back together it fall off again, back I easily pushed it back and installed knuckle and stuff. Now my question is the inner CV boot still look weird, does it matter as long as I am able to put everything back? OR I HAVE TO DO EVERYTHING AGAIN???
Solbros Owns Me
Re: (BANNED_ID)
does the boot look pinched??? just massage the crease out of it. As long as the joints move freely and the boots aren't leaking, you should be cool
shorty0o29
02-24-2004 09:31 PM
Malice
06-21-2002 09:08 PM
