weird idle, bogging, choking after plugging in p2t ecu
when i had the p2e ecu plugged in, car was running fine. after i plugged in a p2t ecu from a 2000 civic si, my car had a weird idle, and when i tried to drive it, it was bogging, and it wouldnt grab. im using this ecu for my mini swap and i just wanna get this **** done already. thanks for any help
The Grumpiest
Re: weird idle, bogging, choking after plugging in p2t ecu
Not understanding. The P2E worked fine? Maybe you need to furnish more info on the setup to stop people from guessing.
Technical Hero
Sounds like you probably have at least one check engine light. I'm going to guess one of the lights is for idle air control. You have to convert from 3 wire to 2 wire. Did you wire up VTEC? Knock sensor? Extend the secondary O2?
mikeunreal2
21
04-13-2006 06:36 PM
