Map Sensor problem
Old Jun 9, 2005 | 10:17 AM
Ej1_coupe's Avatar
Default Map Sensor problem
I recieved a MAP sensor that I purchased off of ebay today. The thing is that it is not the same MAP that is already on the motor, nor does it fit. If I took the bracket off, and cut the plastic under it, I am sure it would fit. Could I use this if I got it to fit? The connections from the wiring do fit, it just does not fit into the throttle body without modification. Thanks
Old Jun 9, 2005 | 02:13 PM
Ej1_coupe's Avatar
Default Re: Map Sensor problem (Ej1_coupe)
Well, it works. I threw a couple CEL's at first, but took it for another drive and beat on it and didn't throw one. So who knows. I would still like to know what car this came off of? Thanks
Old Jun 9, 2005 | 03:11 PM
SwappedTURBOegg's Avatar
looks like a obd0 map..probbly a jdm B16.
Old Jun 9, 2005 | 03:15 PM
Rice Eater's Avatar
Default Re: Map Sensor problem (B16 delSlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16 delSlow &raquo;</TD></TR><TR><TD CLASS="quote">looks like a obd0 map..probbly a jdm B16.</TD></TR></TABLE>
i think so too. my friend gave me his map sensor off a jdm b16 and it look like that. the one i had had two screws holding it down, this one has one. but im not sure
Old Jun 9, 2005 | 05:26 PM
b18c5 EG's Avatar
haha i was going to bid on that map sensor on ebay the other day haha...but if the plug fits it should be fine?
Old Jun 9, 2005 | 05:37 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (94_Del Sol)
Its from a 92-95 Civic. Thats one thats on the firewall. For some reason they made both in that year. Should work the same however.
Old Jun 9, 2005 | 05:56 PM
Ej1_coupe's Avatar
Default Re: (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">Its from a 92-95 Civic. Thats one thats on the firewall. For some reason they made both in that year. Should work the same however.</TD></TR></TABLE>
hmm thats weird. anyway, yea my car is just running lean now, and seems to bog a little bit at idle, but beats the hell out of what it used to do with the old MAP. Oh well. Yes the plug does fit.
thanks
Old Jun 9, 2005 | 06:53 PM
EKB18BPR3's Avatar
Default Re: (Ej1_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ej1_coupe &raquo;</TD></TR><TR><TD CLASS="quote">
thanks</TD></TR></TABLE>
u dont wanna run lean for too long. u may have detonation and ur motor go boom! i would rather run rich then run lean.
Old Jun 9, 2005 | 07:01 PM
LeftCorner's Avatar
90-93 Integra had the MAP mounted on the firewall. Vacuum source was routed behind intake manifold to the throttle body.
Old Jun 9, 2005 | 07:04 PM
Ej1_coupe's Avatar
Default Re: (98B00STED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98B00STED &raquo;</TD></TR><TR><TD CLASS="quote">
u dont wanna run lean for too long. u may have detonation and ur motor go boom! i would rather run rich then run lean.</TD></TR></TABLE>
hmm thinks if that might be the way to go and have an excuse for an engine swap..haha. Anyway, thanks for the info.
Cian Mcloughlin
May 20, 2013 10:11 AM
jw15u
Nov 14, 2009 06:57 PM
dc2doi
Nov 9, 2007 12:16 PM
v8 integra
Nov 15, 2006 08:52 AM
Brian Hinson
13
Jun 24, 2006 04:05 PM
