Temperature is high “cluster gauge, radiator, thermostat, or gasket” ADVICE ONLY
Advices only THANK YOU.
Hey my car overheats going Uphill Street & freeway. But when I stop the tempteture gauge goes up & down up & down like crazy than it stays stable. I check the radiator immediately & the water is not hot is just warm. I check to see if the radiator is leaking no it was okay. Ummmmm should I change the thermostat or the gasket. Or change the cluster gauge.
Thanks, …
Thanks, …
Re: Temperature is high “cluster gauge, radiator, thermostat, or gasket” ADVICE ONLY (kos99ngel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kos99ngel »</TD></TR><TR><TD CLASS="quote">Advices only THANK YOU.
Thanks, …
How hot does the gauge get up to? Have you checked to make sure your fan is coming on? Are you throwing any CEL's? How fast does the temp gauge fluctuate?
Thanks, …
Freeclowns
11
04-14-2012 04:36 PM
96_coupe
40
04-02-2012 10:35 AM
amej8
10-17-2011 08:00 AM
