99 Si Help
99 Si Help
i've gotta 99-00 si, im looking to put a motor in. I have a complete obd2b wiring harness, but im wanting to drop in a b16 obd1 motor. i know i need a ecu conversion harness, my question is what dizzy do i need to use? will a obd2 dizzy bolt up to a obd1 head??????
Guest
Posts: n/a
Re: 99 Si Help (1998 hatch dx)
Ok let me try to help you out as I have been searching for this question myself in the past: (please correct me if I'm wrong)
Whatever dizzy you use is supposed to be with your engine harness, so you use the stock b16a2 obd2 dizzy.
I believe all the sensors in the obd1 head is the same as the obd2 head so you can plug n play. So all you need is the jumper harness, but this I am not completely sure of.
The dizzy will bolt to the motor, but the wiring is different. There is no such jumper harness for the dizzy. Just get a obdII dizzy. You will also have to switch injectors to obdII and your alternator.
dirtyEj1
05-02-2007 05:54 PM
