Do shortshifter have to brake in?
I just installed a tenzo short shifter on my 97 civic coupe, i love it, so much shorter throw. but one problem its really stiff, it takes some muscle to shift now. Does it have to break in? I heard you have to lube the ball before you put the shifter in so I used wd40, had nothing at the time. let me know thanks.
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">you tightened the bottom bolt/nut too much</TD></TR></TABLE>
this could be the case. also, you said you used wd40, I would go back and hit it with some white lithium grease or something
Re: (SpydiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpydiR »</TD></TR><TR><TD CLASS="quote">
this could be the case. also, you said you used wd40, I would go back and hit it with some white lithium grease or something </TD></TR></TABLE>
works wonders, i used this on the ball joint and also think about the bolt connecting the shifter rod to the connecting rod near the exhaust piping. I wouldn't losen it, but make sure it's not over tightened.
i have to break-in my skunk2 short shifter cuz the ball bearing is still kinda sitff. after a couple of hours of driving, youll notice the real difference from stock.
p.s. will post pics of my shifter soon....
too lazy, just got off work...
