Nother Headlight Problem....
My passenger headlight only works when I put the hazards on, then turn the lights on. Sometimes I would have to turn my radio off. It recently stopped coming on even if i did this. The high beams work perfect, but the low beams are a no go. All wiring, that was done by me, is good.
I think this is a power problem. I did do some soldering, but everything has been checked. I am thinking it is where the low beam power wire(s) ends up. So what I am looking for is where the low beam power wire(s) connects to. Fuse Box? ECU?
All help is appreciated thanks.
thats a werid problem i suggest just tapping this headlight to the other one so they both turn on at the same time, altho they might be a little bit dimmer than before depends on how much this bothers you
Re: (robbie_R(eg6))
Interesting, but if that doesnt work, I know its my product, but like I said it was working just recently. I never thought about tapping it. I thought they were tapped into each other already.
BTW: All fuses look good.
im pretty sure they run of separate circuits either way one is turning on fine even just tap the low beam wire would probably do it, and which product were u talking about?
DAprojectTuRtle
Honda Civic (2001 - 2005)
04-16-2012 02:41 PM
Uncle Ben's
07-08-2007 12:08 PM
