Need help with 92 civic
I have a 92 automatic civic lx that recently broke down. When you start the engine all you hear is a grinding sound and all the oil is leaking out. My friend told me that I need a new engine. My question is, How much would it cost to put a low mileage engine in this vehicle and is it worth it.
Also, can you recommend any good mechanics in NJ or NY that could do the work?
Re: Need help with 92 civic (casual)
you could one in a junkyard for like 200 - 500 bucks. i wouldnt pay more than 200 for that motor and no more than 500 for the labor. you may be able to fix the one you have . but your not rally going into detail with waht is going on and what you did to make it like that
So basically I should not pay more than $700-800 for everything.
The story is this. I let my girlfriend use it while I went away and when I came back it was like that it was oil everywhere. The guy who looked at it says there is a crack ...............somewhere, I can't remember now. But just the fact that it is grinding like that does not sound like something that could be repaired. I would have a mechanic look at it but that would require towing and I do not know any mechanics in the area
Re: (casual)
best thing to do is clean off all the oil u can see under the car best as u can then start it up and see where the oil is leaking from just leave it on long enough till u se oil on the floor. grinding from a motor is repairable depending on what is grinding. how many miles on the car, check your dipstick is there any oil on it at all?? u can find a decent motor for about 300 i would say and labor ya 500 sounds about right good luck sounds to me like it might just be worth getting a newer car if u dont want all the hassle.
The car has about 120,000 miles on it. I really want to try to fix it because the body and everything is clean and it has basically been reliable from the day I got it. THere is no oil in it now because basically all the oil has leaked out
