Thorwin some codes..
Old 09-14-2005, 04:24 PM
riceburnerryan's Avatar
Default Thorwin some codes..
so i have a GSR in my EG coupe and the other day my CEL came on ... well it was from my VAFC wires being disconnected ... well one of my friends old me if i pulled the ECU fuse and tured the car over it would erase it .. well now my car wont start.... i have taken it to a shop and the car is throwin code 15 and 20 ...
code 15
Ignition Output Signal
missing or defective ignition output signal
code 20
Electrical Load Detector
defective circuit or unplugged / defective sensor
i was told it was my dizzy but he has 12v from the cap and to the cap and from the coil also
i was told a new ignitor? letme kno
Old 09-14-2005, 04:50 PM
SL!M's Avatar
if the dizzy is not new, and should be replaced then I would do a whole unit, the price of a friggin ignitor is nearly the cost of a unit. I just went through that bullshit.
P.s don't listen to your friends.
Old 09-14-2005, 06:54 PM
Default Re: (SL!M)
thanks man .. yeah i wont listen to my friends again .. hey also ... does anyone know what a VTM sensor is ... i saw it in the manual for my VAFC
let me kno you guys! thanks!
Old 09-14-2005, 06:56 PM
Default Re: (SL!M)
*sorry for the double post*
also .. did that fix your problem ? and were you throwing the same codes?
Old 09-15-2005, 10:00 AM
Civic92jak's Avatar
Talkin to ya on aim .
Old 09-15-2005, 01:47 PM
Default Re: Thorwin some codes.. (riceburnerryan)
so ... new ignitor didnt work ... ordered new dizzy
Old 09-15-2005, 09:27 PM
Civic92jak's Avatar
Sorry to hear bro. Leads me to believe its the coil from what you explained to me. But a new Dizzy is always a good way to go.
Old 09-16-2005, 05:32 PM
Default Re: (Civic92jak)
we have lead to beleive its the main relay... let me kno ??
Old 09-16-2005, 06:42 PM
HondaFanatic708's Avatar
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: (riceburnerryan)
For the code 15, check for battery voltage on the BLK/YEL wire at t he dizzy with the ignition in the on position. If you get voltage it could be the ICM, wiring between the ICM and ECU or the ECU. If you don't get voltage check for a short in the BLK/YEL wire.. The ELD wouldn't keep the car from starting. Just an FYI the 7.5a fuse under the hood is to reset the ECU but you just remove it for a few seconds and its reset. Never did it myself, but maybe turning the key when that fuse was removed fried some things as said...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SL!M &raquo;</TD></TR><TR><TD CLASS="quote">
P.s don't listen to your friends.</TD></TR></TABLE>
But before you go throwing parts at it I would run through the troubleshooting flowcharts in a factory service manual. I'm sure if your nice your local Honda dealer would let you make copies of the needed pages.
Old 09-16-2005, 07:08 PM
Default Re: (HondaFanatic708)
thats the problem .. there is voltage at the ICM the coil and the cap and everything we replaced everything and still nothing .. i heard the main relay ... so i am gonna try that tomorrow other than that.. i donno
Old 09-16-2005, 07:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFanatic708 &raquo;</TD></TR><TR><TD CLASS="quote">But before you go throwing parts at it I would run through the troubleshooting flowcharts in a factory service manual. I'm sure if your nice your local Honda dealer would let you make copies of the needed pages. </TD></TR></TABLE>Just to reitterate my opinion..
Old 09-16-2005, 07:47 PM
i went to honda of spokane today and got some things from them .... nothing so .. hopefulyl main relay
Old 09-16-2005, 08:01 PM
Yeah if you ran all the way through the troubleshooting flowcharts for your CELs they should be solved. I really think whatever is causing the DTC 15 is also keeping the car from starting.
Old 09-16-2005, 08:26 PM
thing is .. i have power to everything! its weird
Old 09-17-2005, 09:29 AM
so i replaced the master relay and code 20 is gone i now am throwing 21 and 15 21 is like ... spool solenoid?
HELP ME PLEASE!
Old 09-17-2005, 01:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFanatic708 &raquo;</TD></TR><TR><TD CLASS="quote">But before you go throwing parts at it I would run through the troubleshooting flowcharts in a factory service manual. I'm sure if your nice your local Honda dealer would let you make copies of the needed pages. </TD></TR></TABLE>What I should have said is your local Acura dealer since you would want the flowcharts for the GSR. If you follow the flowcharts it will direct you to the root of the problem.. And you CEL will go away, most likely allowing the car to start.
Old 09-17-2005, 03:14 PM
no acura in spokane that i kno of.. im going to tow it to honda and have them takea crack at it
Old 09-17-2005, 08:38 PM
Civic92jak's Avatar
Code 21 is:
21*- Accord Civic CRV CRX Del Sol Odyssey Prelude
94-98 ** 92-95 n/a n/a 93-95 n/a 93-95
VTEC Solenoid Valve
defective circuit or unplugged / defective solenoid valve
* not a valid code if car does not have a VTEC engine
** not with V-6 engine
Code 15 is:
15- Accord Civic CRV CRX Del Sol Odyssey Prelude
90-95 88-95 n/a 88-91 93-95 95 88-95
This might help you alittle better . Seems like the not starting problem lies in the code 15. This could also be causing the code 21. Hopefully you can figure something out soon.
Old 09-17-2005, 11:02 PM
k so i kno why im throwing 21 and 22 .. its becuase when i did my VAFC .. the ****** didnt connect the wires right so they are disconnected right now .. either way do you think the VTEC wires not being connected would really affect the no spark even tho i have power to my distributor and ****? thanks james.. only thing i can think of now is tow it to honda and have them ****** fix that ****...
Old 09-18-2005, 04:04 AM
2lua's Avatar
vtm= vtec module.
it is the blue wire came from the vafc right? you need to hook it with the vtec pressure switch to the ecu.
Old 09-18-2005, 01:09 PM
Default Re: (2lua)
so the only codes im throwing now is like.. 15 and thats prolly whats not starting my car... i was throwing a code.. the spool solenoid but that i think has to do with VTEC ?? i have all my VTEC wires connected ... but car ont start so i rented a uhaul truck and trialer and gonna drop that piece of **** off at honda so ... i guess its in their hands now...
Old 09-18-2005, 01:32 PM
Civic92jak's Avatar
Seem like something else failed inbetween the ecu and the dizzy. Taking it to the nearest Honda/Acura dealer is about your only hope. Wish i was closer man, i would come over and look at it for ya.
Old 09-18-2005, 01:41 PM
thanks james... but yeah .. im just fed up with not having a car and using my girlfriends.. its an inconvinience and i just need my car back so i was like.. ill rent a uhaul truck *cheapest towing* and just pay the extra to have the job done right
Old 09-19-2005, 05:46 PM
so i took my car to honda... and its now fixed... in a grand total including towing it was 300 bucks.. wanna kno what was wrong? well it was one of the wires came loose form the shoddy VAFC wiring and well .. that cuased no signal from the ECU to the dizzy ... which in turn .. caused no spark thus not allowing my car to start... well ... now its fixed and i even got a cool new honda shirt! yay!
Old 09-19-2005, 08:34 PM
Civic92jak's Avatar
good to hear mang. Now you don't want to get rid of it right ?
ketchup214
04-17-2010 03:03 PM
riceburnerryan
09-15-2005 09:54 AM
90crvtec
08-19-2005 07:19 PM
neo1z
10-07-2003 11:01 PM
sidwin
06-04-2003 06:31 AM
Quick Reply: Thorwin some codes..
