slave cylinder
Old 09-14-2005, 12:28 PM
stickman12's Avatar
Default slave cylinder
I have a 92 civic and the clutch cylinder has been acting up. (don't know if it is the master or slave that has the problem). So I tried to manually bleed the system, and I can't seem to get any pressure at all now. Please help, any sugg. taken.
Old 09-14-2005, 01:22 PM
Jowee's Avatar
Default Re: slave cylinder (stickman12)
How did you bleed the system? What's it doing exactly?
Old 09-14-2005, 01:31 PM
ThatsMyEG's Avatar
Is it leaking fluid? if so your master cylinder is probably bad or you have a leak somewhere else or your just bleeding them wrong..
Modified by ThatsMyEG at 3:04 PM 9/14/2005
Old 09-14-2005, 02:09 PM
BenzTek134's Avatar
Default Re: slave cylinder (ThatsMyEG)
how did u bleed the slave cylinder? u sure u were doing it correctly?? do u have fluid in ur master cylinder?
Born2Build
05-22-2011 06:02 PM
djkurious
05-19-2009 04:22 PM
Jay Dirt
10-26-2007 05:27 PM
redman223
06-03-2007 03:58 PM
97teg415
08-01-2002 09:45 AM
Quick Reply: slave cylinder
