del sol leak problem!!
ok i just got a del sol, today it was raining and i noticed that water was leaking in from the window top molding...does this happen to all del sol's...someone told me thats normal for a del sol..but anyway has this problem???
Re: del sol leak problem!! (cuban0)
check your window seal when cars get older the seals tend to split and crack and can cause water leaks check that then maybe if it is still leaking and u dont wana replace the seal u can adjust ur door striker inwards which will bring ur door in further preventing possibe leaks depending how bad it is. oh by the way ur door striker is the piece ur door closes against on ur car it should have one screw or 2 maybe its metal and has a latch on it also
Re: del sol leak problem!! (BenzTek134)
i have a 93 sol si and it only leaks if rains ALOT. It's only from the spot where the regular driver window meets up with that triangular window, happens on both sides though.
Re: del sol leak problem!! (93c1sol)
yeah it is from both sides..well today it was raining hard so it leaked, it was shoer inside the car but acouple of drops and stuff....thanks for u input
Re: del sol leak problem!! (Archillion)
silicone grease is a great temporary fix, but you'll have to reapply it every so often. this is a common del sol problem that honda fixed in the 95+ sols. For a permanent fix, buy the weather stripping for a 95+ sol and replace yours. Its some $ for a few pieces of rubber, but you'll be leak free.
Re: del sol leak problem!! (IHateJDM)
thanks for the info i have a 93 sol with the same problem and its pourin like crazy out here right now...i have been coverin my seat with a trash bag and towel to catch the rain water from gettin on my seat.
mikeycivics
10-04-2011 09:13 AM
Squallie
27
10-07-2005 04:56 PM
Boostless97Lude
11-24-2002 10:28 PM
