92 Honda Civic Engine Idle Problem Help
Hi, my name is Buddy and I drive a 1992 Honda Civic DX 5 speed. My engine is idling around 2,000 - 3,000 rpm and that is more than the manufacture level. I checked the computer and it is not giving any codes. I changed the PCV valve, removed the intake hose and cleaned the throttle plate with gum-out carburetor
spray and still i have the same problem. Can someone help me with my problem??? thanks a lot...Buddy.
Re: 92 Honda Civic Engine Idle Problem Help (Buddy10297)
Sounds like a vacuum leak. With the car running spray carb cleaner around the vacuum hoses and ports. The engine speed will change when you spray the leaking component/hose.
JDMguyss
13
01-09-2007 07:31 PM
labgeek
06-15-2004 07:42 PM
