2000 civic si help!!!!!!!!
ok i bought a 2000 civic si today from a repo auction so i dont know much about it.. first off the motor is in the trunk of the car. i noticed it is a b18 block which is not correct.. the head is there and i didnt look at it to well but it looked ok. now what i want to know is what b16 motors will fit in the car without modifications? such as rewiring.. would it be easier to use the b18 block and put a b16 head on it. i have some knowledge to this. i put a b16 in a crx once but that was a couple years ago so i need some help.
Re: 2000 civic si help!!!!!!!! (jsteezy1290)
sell the engine you have and buy a 00 b16 if you want the stock effect other wise slap a b16 head on your b18 block( which is it a b18c block or b18b?) as for trannys look at the stamping !
If I were in your shoes I would Keep the B18 block and throw the B16 head on it. I found you get a much faster rev and poss. a little more power off the line. Also be sure to use B18 head bolts, ( they are longer) because when I did the swap I accidently used B16 bolts and stripped the holes in my block. As for the LS tranny look for the stamp on the side.
Re: 2000 civic si help!!!!!!!! (JDM97EK)
make sure you look over the head thuroughly though, dont forget to check cams and **** like that, wouldnt want to ruin a motor that might not have been fucked up in the first place... but yeah go with the b18 block and keep the head if its in good enough condition.
Re: 2000 civic si help!!!!!!!! (jaydeeumms)
how do i find out if my head is even a b16 head? not sure on the block i will now tomorow and have pics for all of you. regardless i plan on taking the head to the machine shop to get tested.
ok the block is a b18a1, and the head says pr3-2. the head is scared from the cams and i took it to my shop and they said they couldnt fix it. looks like it was due to lack of oil. what setup is this?
PR3-2 sounds like a B16 head. I want to make sure though, but I believe I was seeing this all over my head when I was doing my rebuild. That sucks that it is damaged. Look at the exhaust manifold side. You'll see 4 circles with numbers in them. This tells you the year and stuff. Can't remember what means what though. Good luck with your project.
I have an 00 Si and will sell my b16a2 swap. Motor has DC4-1 AEBS manifold and a quaife exedy clutch and toda flywheel. Interested? PM me if you are.
if you want a stock motor for an em1 it would be a b16a2. the head should be an si head from the pr3 stamping your talking about. does it have a transmission and wiring harnes. if it does just buy a b16a2 longblock and call it a day.
Re: 2000 civic si help!!!!!!!! (slammed00si)
yea it has the wiring and tranny, but should i get a b16a2 head again? does this setup starve the head for oil?
what block is it? b18a/b b18c?
it shouldnt starve the head for oil the oil pump may be bad in the block. just for simplicity i would buy the longblock and call it a day sence the block is unknown.
I remember a company making an engine called "The Beast". Didn't they use a B18 block and B16 head... **** that thing was rated at 297 horses or somthing.
If the head and block are good... I'd shoot for a Beast Replica!!
ditch the block its an obd1 ls. it means its old as hell. just get a b16a2 longblock and call it a day. you can do the b18a1 but it will need to be rebuilt from the sounds of it. basicaly if the head is crap i bet the block is to.
ya but just because the head is crap doesnt mean the block is. isnt this motor setup supposed to be a asskicker?
