11 second b18b1
Re: 11 second b18b1 (adamsjm5)
Big turbo, crazy internals, many lbs. of boost. What a noob question..it also depends on the car weight etc., These types of questions can only be given theorized answers, so what's the point?
visit here: https://honda-tech.com/zeroforum?id=49
plenty of cars run in the 12s w/ internally stock b18bs.
even d16s.
reading > posting
even d16s.
reading > posting
Will you make something up for me please?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adamsjm5 »</TD></TR><TR><TD CLASS="quote">What needs to be done for a 95 civic coupe with a b18b1 swap to run 11's?</TD></TR></TABLE>
Bottom line, you need a turbo with a built motor for a Civic with an LS to go 11's. Do some research in the Forced Induction forum to see what you will need in terms of motor reinforcement, engine management, and turbo kits.
Re: 11 second b18b1 (shamoo)
i seen alot of ls motors that isnt built with stock internal that runs 11s.
they been running it a year or two.
get a turbo kit with a good tune to it. also have a good set of tires
haha my bad on the noob question, i kind of left a little bit of info out. I meant to ask what needs to be done to the ignition system of a 95 civic coupe with a b18b1 that is already built and turboed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adamsjm5 »</TD></TR><TR><TD CLASS="quote">haha my bad on the noob question, i kind of left a little bit of info out. I meant to ask what needs to be done to the ignition system of a 95 civic coupe with a b18b1 that is already built and turboed.</TD></TR></TABLE>
nub....search, google is tEh bestest, of the bestest friend ever!!
Re: 11 second b18b1 (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">i seen alot of ls motors that isnt built with stock internal that runs 11s.
get a turbo kit with a good tune to it. also have a good set of tires</TD></TR></TABLE>
This is true, I forgot I was in the Civic forum. I usually hang out in the Integra forum, and I don't know of any stock LS blocks running 11's in an Integra. I've heard mid 12's on slicks and a moderately stripped interior, but that's it.
In a lighter Civic, I believe it.
http://www.hondaswap.com/forum...32119
ALL MOTOR
edit i don't think it'll run 11's though.
Modified by NerveAgent at 11:57 AM 9/14/2005
ALL MOTOR
Re: (NerveAgent)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NerveAgent »</TD></TR><TR><TD CLASS="quote">http://www.hondaswap.com/forum...32119
ALL MOTOR
Modified by NerveAgent at 11:57 AM 9/14/2005</TD></TR></TABLE>
nope. it wont. 150-170 is not enough to run an 11 second 1/4 mile time.
on a stock LS motor, you'll need a hefty size turbo (research) and a real good tune.
if you wanna pull some more power without increasing the boost level, throw some money into the head (port work, cams, etc).
ALL MOTOR
