misfortune with my 00 si
So to start... my si started burning oil like 20k ago... im a full time student and work full time aswell so i havent really had a chance to take her apart to find out whats going on. 3 weeks ago im driving down the 10 freeway and i just feel a massive power loss and started decellerating my check engine light started flashing and i knew i was fucked . i got home and did a compression check on her.. and had no compression on the # 2 cylinder i decided to take her apart 2 days ago cuz i finally got a chance too... and my end results were a broken valve and a bunch of other burnt valves in addition i had some pretty bad carbon build up considering that i did a decarb service only 7k ago.. im guessing what happen was since i had so much carbon on my pistons it just made my cumbustion chamber temp really high and burnt the **** out of my valves.. and my oil consumption... since it was like...a quart every 3 days for like 150 miles im guessing my oil rings were bad.. i still need to take the bottom block apart...
Modified by code415 at 2:21 PM 9/16/2005
Modified by code415 at 2:22 PM 9/16/2005
Modified by code415 at 2:23 PM 9/16/2005
Modified by code415 at 4:37 PM 9/16/2005
Re: misfortune with my 00 si (M2nR22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2nR22 »</TD></TR><TR><TD CLASS="quote">damn thats sucks bro. hey out of curiosity how do you know or how can you tell if your engine is burning oil?</TD></TR></TABLE>
Check the dipstick, dipstick
Re: misfortune with my 00 si (PURPLETERROR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR »</TD></TR><TR><TD CLASS="quote">
Check the dipstick, dipstick </TD></TR></TABLE>
...uhh DUH! but what do you look for?
grammer nawzi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2nR22 »</TD></TR><TR><TD CLASS="quote">...uhh DUH! but what do you look for?</TD></TR></TABLE>
Was that serious?
Was that serious?
you cant be serious you look for a loss of oil on the dipstick. if you are losing oil and you dont have a leak you are burning it!!!!! hell, if ya check the oil and it is going down you have a problem somewhere..........this is amazing. you are the reason we call it a "DIPSHIT stick" at my shop.
Re: misfortune with my 00 si (code415)
If you need any advice I just rebuilt my bottom end. Everything is still very fresh in my mind. I blew the ringlands in all my cylinders and had low compression. I wasn't burning oil though. Good luck with it and all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by code415 »</TD></TR><TR><TD CLASS="quote">So to start... my si started burning oil like 20k ago... im a full time student and work full time aswell so i havent really had a chance to take her apart to find out whats going on. 3 weeks ago im driving down the 10 freeway and i just feel a massive power loss and started decellerating dramasticly my check engine light started flashing and i knew i was fucked . i got home and did a compression check on her.. and had no compression on the # 2 cylinder i decided to take her apart 2 days ago cuz i finally got a chance too... and my end results were a broken valve and a bunch of other burnt valves in addition i had some pretty bad carbon build up considering that i did a decarb service only 7k ago.. im guessing what happen was since i had so much carbon on my pistons it just made my cumbustion chamber temp really high and burnt the **** out of my valves.. and my oil consumption... since it was like...a quart every 3 days for like 150 miles im guessing my oil rings were bad.. i still need to take the bottom block apart...
Modified by code415 at 9:10 PM 9/15/2005</TD></TR></TABLE>
drastic + dramatic = dramasticly lmao
Re: misfortune with my 00 si ({PBA}Threat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by {PBA}Threat »</TD></TR><TR><TD CLASS="quote">drastic + dramatic = dramasticly lmao</TD></TR></TABLE>
I saw that too. Lol
I saw that too. Lol
srry i forgot to add pics was kinda late... to answer ur questions mod wise its stock. planing to build the head and go turbo with a b18b block.. just trying to finish up school first..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by code415 »</TD></TR><TR><TD CLASS="quote">srry i forgot to add pics was kinda late... to answer ur questions mod wise its stock. planing to build the head and go turbo with a b18b block.. just trying to finish up school first..</TD></TR></TABLE>
cant see pics = [
cant see pics = [
Re: (yoursupahero09)
you gotta find the properties of his links and manually type them in, at least I had to.
Is that carbon build up that bad? Maybe they aren't good pics or I don't knwo what i'm talking about, just curious. Seemed like normal blackness as far as the pics I've seen on here, never taken an SI apart myself.
stupidceleb
11-21-2010 09:59 AM
vtecmike1
03-27-2004 07:24 PM
