i need a quick answer to a stupid question: ground wire
i dont think my valve cover ground wire is connected right anymore, the car feels slow in accelerating. anyway, heres a dumb question, i plan on fixing it, but do i have disconnect the battery first to avoid any danger?
Location: Where the shooting range is on the streets of LA, CA.
Re: i need a quick answer to a stupid question: ground wire (Wazup)
what danger would you be avoiding? i mean if your just gonna replace the ground wire then your car should be fine... unless you wanna sit in your car and preset your headunit again cuz u pulled the battery out... but other then that, your fine... replace it with a thick kind of ground wire too...
disconnect battery when there's a possibility of a short.. since you're dealing with ground only, no need to disconnect it from battery... even though as a safety precaution, it's
always a good idea to disconnect power when dealing with electronics
bad ground could affect certain sensors which could cause sluggishness in general.. tight, clean grounds are always a good thing
Coopa B18c5
05-06-2013 02:09 PM
