50 Shot on b16 civic SiR , ur views?
i have a SiR civic ek-4, has minor modifications - ek9 ECU,aem 3" cold air intake,header, fuel pressure regulator, vafc, lighten flywheel/stage 1 clutch/stage 3 pressure....car is very fun to drive but now i want more power....a friend of mine has a Zex Dry Nitrous Oxide Kit with a 50 shot jet that he is willing to sell, i am interested to know is a 50 shot SAFE on the stock b16a motor?...i really dont want to do anyting that will harm the engine whether short term or long term, i dont intend to use the kit alot only wen im racing...i have friends who have put bigger nitrous shots(70) on their b16's and have had to change rings,etc so im jus enquirin about the pro's and con's of using a 50 on a b16a
Re: 50 Shot on b16 civic SiR , ur views? (SiRb16)
ya ur 50shot should be fine as long as you use it wisly. i mean don't use it every single race you have if u are a little behind then hit the spray but if its a car you think you can beat then leave the spray alone. your be fine if you dont get nitrous happy.
Re: 50 Shot on b16 civic SiR , ur views? (95 RED CIVIC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 RED CIVIC »</TD></TR><TR><TD CLASS="quote">ya ur 50shot should be fine as long as you use it wisly. i mean don't use it every single race you have if u are a little behind then hit the spray but if its a car you think you can beat then leave the spray alone. your be fine if you dont get nitrous happy. </TD></TR></TABLE>
A 50 shot is fine, I personally would get a wet system, but as long as u dont get trigger happy u will be fine. you wot get burn
hoffmanb16
11
03-11-2009 12:01 PM
