fuel problem help
fuel problem help
i finished my setup, d16z6 and boosted at 7psi. Im usin an fmu and it seems to me like its not kickin in. When i hit boost my a/f gauge grops to lean and the car doesnty go. When i hit boost on the highway my cel came on and started to idle like ****. turned car off and drove under boost and cel light is gone. My fmu was laying around for a month after use is this my problem? is my fmu gone?
Re: fuel problem help (silverboost)
get a fuel pressure gauge and mount it on your windshield. watch the fuel pressure as you boost.. the fuel pressure should rise to like 60 psi from about 30. if it drops pressure as your boosting then your not getting enough fuel pressure from your pump... check for any leaks, none? you then would first change your fuel filter, if that doesn't do it, you need a fuel pump.
good luck!
good luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverboost »</TD></TR><TR><TD CLASS="quote">i have a walbro 255 intank feul pump</TD></TR></TABLE>
remember even a new part doesn't mean its a good working part. could have went bad...
BorderM3
11-05-2002 10:54 AM
HybridCoupe
07-06-2002 03:48 PM
