D15B Dizzy?
Old 01-28-2006, 08:37 AM
aXhatch's Avatar
Default D15B Dizzy?
I have a JDM D15B motor. I am ready for the swap just about, but I do not have a Dizzy for the d15. I was wondering if anyone knew WHAT dizzy other than another d15b would work for it?
ANd does anyone know if the water pump is the same as the z6 even though they are different displacemnt.
Old 01-28-2006, 08:42 AM
clint g's Avatar
Default Re: D15B Dizzy? (aXhatch)
any d series dizzy should work the rest i dunno
Old 01-29-2006, 07:35 AM
aXhatch's Avatar
Default Re: D15B Dizzy? (clint g)
well that doesnt seem to be true my car is now in the garage. The D15b7 (non vtec USDM) bolt holes dont line up AT ALL with the d15b. The d16z6 seems to work, but I ahve to install it and run it to see if its ok.
-aXhatch
So for anyone who needs to know, the D15B7 dizzy WONT fit a D15B JDM motor.
Old 01-29-2006, 08:14 AM
NineTwoSi's Avatar
z6 for sure!
Old 01-29-2006, 08:39 AM
coquitlamEG's Avatar
Default Re: D15B Dizzy? (NineTwoSi)
you're right, the d15b7 dizzy holes don't line up with the d15b vtec but you can still use your old dizzy with just a few modifications. When i did it, i just used an angle grinder with a cut off wheel and trimmed out the holes on the dizzy. The dizzy has those slits that allows you to twist it to set the timing. You just want to open up the slits so one end is completely open. then you can just use your stock bolts with a large washer to hold it in plance. It's kinda hard to explain without a picture. I'll try to take a pic of mine and show you.
Old 01-29-2006, 12:02 PM
aXhatch's Avatar
Default Re: D15B Dizzy? (coquitlamEG)
Thanks for the tip. Its sunday So i cant get a dizzy yet (new one at least) and i BELIEVE i know what your talking about. Im going to take some time right now to go look at it. thanks for the help again
-aXhatch and a pic if/when u get it up would be cool too, or I could post one if mine works.
Old 01-29-2006, 12:15 PM
street dreams's Avatar
Location: chillin in that city called queen creek, but homes the atl
any d-series vtec dissy should work from a d16z6 , d15z1 vx, and a zc vtec dissy
Old 01-29-2006, 12:53 PM
littleblue's Avatar
Location: On a island w/ only a bridge to leave it, U.S.A
Default Re: D15B Dizzy? (street dreams)
Just dont buy one at autozone I went through 4 dizzys before I went to a foreign auto supplier...
Old 01-30-2006, 06:14 PM
aXhatch's Avatar
Default Re: D15B Dizzy? (littleblue)
i stole one off my friends girlfriends car, 94 del sol si (1.6 vtec) and ran it, my ECU wasnt chipped but the motor ran fine, I just didnt have vtec due to no wired vtec solenoid.
I ordered a del sol si dizzy from Distributorking.com ?? My friend has ordered about...3 from them and have no probs, one had a short someplace and it was replaced free of charge....3 year warranty
Should be here in 2 days, I have chipped ecu...now all i need is dizzy...
waiting sucks
-axhatch
Old 02-03-2006, 08:31 PM
aXhatch's Avatar
bump for DIzzy I have.
I got the correct dizzy...and the no vtec wires dont work. I tried 94 del sol si (SOHC vtec) wires fit perfect so i have to order a pair.
IS it possible that all NON VTEC wires dont fit correctly? they are too small on end where wire goes over spark plug.
koalayummies
11-17-2011 03:04 PM
preludeboybmw
16
10-14-2008 06:33 PM
kabaroo
05-25-2005 12:01 PM
rexizbest
02-01-2005 05:35 PM
Magick211
14
11-12-2004 07:30 PM
Quick Reply: D15B Dizzy?
