CEL on getting P0420
Old 01-28-2006, 02:16 AM
pumpkyn's Avatar
Default CEL on getting P0420
Catalyst System Efficiency Below Threshold (Bank 1)
Now that is the O2 sensor after the Cat, right?
Old 01-28-2006, 04:06 AM
Mr. Badwrench
boostedcivicsir's Avatar
Default Re: CEL on getting P0420 (pumpkyn)
yes. highflow? gutted? sim?
Old 01-30-2006, 04:05 PM
pumpkyn's Avatar
Default Re: CEL on getting P0420 (boostedcivicsir)
stock cat, plus while driving the light went off by itself.
Old 01-30-2006, 04:48 PM
In a Junkyard near you.
Ross 2.0's Avatar
You might have an o2 sensor goofing up. The catalytic converter could be the culprit. Get your hands on an infrared thermometer and take two temprature readings at the converter one in front and one in the back. There should be 100 degrees difference between the inlet and outlet witht the car running and hot. If there is 100 degrees or more the converter is good and you have an o2 sensor going bad.
Old 01-30-2006, 05:06 PM
hondamonkey's Avatar
is that the first o2 sensor or the second....because i have the same code...but im not sure which sensor i might need. The second sensor is way more expensive than the first one. Anyone know for sure??
Old 01-30-2006, 11:59 PM
pumpkyn's Avatar
Default Re: CEL on getting P0420 (hondamonkey)
Im getting the Denso universal which is $60 for both. im going to replace the one after the cat first. Should I replace both sensors at teh same time? or is one just fine.
And thanks for the throstat idea im going to try that out
sfgiants11
06-05-2005 07:22 AM
13link EG
10-13-2004 09:18 PM
Nero2007
11
07-28-2004 04:22 PM
Canuk_SiR
07-18-2002 02:42 PM
degradated
11-05-2001 02:57 AM
Quick Reply: CEL on getting P0420
