Problem Starting
Problem Starting
I am new to the forum, and since I am a trial user I only have 5 posts so I am going to include as much information about my problem as I can. I have a 95' Del Sol Vtech DOHC. I have about 135,000 miles on it. It is the limited edition green isle pearl which they only sent 500 to the US. The other day I was driving down the road and it started running real rough. Then the more gas I put in it, the slower it got until I pulled of to the side and it just shut off. I had it towed home. I was thinking it my be my fuel pump or fuel filter but I checked them and the fuel is flowing fine. So I took out a spark plug wire and tried to see if it would spark but it didn't. None of them did. I replaced my distributor cap and rotor and that didnt help. My mechanic said that hondas have a common problem in the distributor. I think he said its a bushing or something, and that it is easier to replace the entire distributor. Before I go and sink 300 dollars into something I cant take back if that is not the problem, I thought I would ask here. Thanks a lot.
Re: Problem Starting (machopeewee)
bump cause i'm having the same problem with my 93 si and checked the same stuff.
https://honda-tech.com/zerothread?id=1507080
please let me know if you find the answer and i'll do the same.
be professional
Check the ignition coil and the ignitor inside the distributor. Those are the most common causes of a no-spark situation.
this happend to my car, except i couldnt start it at all, and it was throwing a code for the ELD and ignitor... check the ignitor, and all the connections to the dizzy, also try and get the codes if your car is throwing any
girlieracerk
12-18-2003 10:12 PM
civicspeed77
11
06-02-2003 07:16 PM
