93 Civic - Clutch Slave Bleed Screw
I have a 93 Civic EX, and the bleed screw on the clutch slave was sheared off. I succeeded in getting that out, but how do I find a new one? I'm not sure what size it is or where to acquire a replacement. Any help on the size? (I'm guessing that I can't just use a brake bleeder screw.) Thanks.
Re: 93 Civic - Clutch Slave Bleed Screw (93civic2005)
regular parts store would have it too get a speed bleeder while you are at it.
one way valve in the bleeder means no air can get it while bleeding
If a bleed screw is about $3 ea and a new slave cylinder is about $15, me personally I'd just get the new slave cylinder; you get a new bleed screw with it plus having the bennifit of a new cylinder.
Re: (93civic2005)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93civic2005 »</TD></TR><TR><TD CLASS="quote">A new slave pushes $30 at least, generally. </TD></TR></TABLE>
http://www.stopshopanddrive.co...e.com
$14.54 for a new clutch slave cylinder from sanyco, a leader in OE hydraulic parts for asian car makes. They also make caliper-blanks for Stoptech. So unless you have to have nissin, which is generally the OE maker for Honda, the sanyco will work fine; I have one it works great. Go to kragen and the one from raybestos is $19.99: http://www.partsamerica.com/Pr...60025
Re: So unless you have to have nissin, which is generally the OE maker for Honda, the sanyco will w
Ahh, I see what you mean. Noobs like me are wary of generic parts, especially when there's no picture. Thanks for the info though. It's good to know for next time.
bluenc-87
04-30-2010 08:53 AM
