Slave Cyclinder / Clutch Cyclinder
Ok heres the scoup, I have a 92 HB Si, and the clutch has about 2 inchs of play, before it does anything, my first thought was ok it just needs to be adjusted
The other day it began to stick about midway when I was disengauaging. I looked today and there seems to be something broken, theres a bunch of excess grease.
Is the slave cyclinder gone? If so how hard is this to replace? I have a manual (bought it for wiring) but its like "here is picture".. "there are 2 bolt, remove and replaxe"
Is there a walk through for this?
Thanks In Advance
-Cody
Thanks In Advance
-Cody
Re: Slave Cyclinder / Clutch Cyclinder (CodyC142)
Sorry for premature bump, Just want to get started on this before dark
Thanks
-Cody
Thanks
-Cody
remove clutch hardline from slave.
remove two bolts on slave.
remove bleeder and install in new slave if not already.
pull on plunger to remove it and the boot and install on new slave if not supplied
grease ball head of plunger
reinstall slave on tranny with original bolts.
install line on slave.
find friend and 6 pack.
have friend help you bleed line just like a brake caliper
