2000 Si Block
2000 Si Block
My cylinder #4 has 2 pretty good size groves right in the cylinder walls, they're kind of deep, causing motor to burn oil. Is it pretty expensive to resleeve with a new stock sleeve since I only need to do one? I called around and not many shops can resleeve honda blocks. Am I better off buying a used one?
Re: 2000 Si Block (that one doood)
my block is already over bore from 80mm to 81.5, can I still go a little larger? I was told that this is kind of max for stock bore on the B16A2.
been there done that
Re: 2000 Si Block (Evil_1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil_1 »</TD></TR><TR><TD CLASS="quote">my block is already over bore from 80mm to 81.5, can I still go a little larger? I was told that this is kind of max for stock bore on the B16A2.</TD></TR></TABLE>
uhhh stock is already 81mm. you can safely go to 82mm on the stock sleeves, unless you boost it then no way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by that one doood »</TD></TR><TR><TD CLASS="quote">uhhh stock is already 81mm. you can safely go to 82mm on the stock sleeves, unless you boost it then no way.</TD></TR></TABLE>
Thanks for the correction on the bore. I haven't been to focus on this car for the longest time. I forgot alot about this car. Here's a photo, do you guys think going to 82mm would clear the scratches? Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil_1 »</TD></TR><TR><TD CLASS="quote">Thanks for the correction on the bore. I haven't been to focus on this car for the longest time. I forgot alot about this car. Here's a photo, do you guys think going to 82mm would clear the scratches? Thanks
Damn those look like a few mm's deep. What broke or got into the cylinders to cause that?
Re: 2000 Si Block (JeffBro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeffBro »</TD></TR><TR><TD CLASS="quote">Damn those look like a few mm's deep. What broke or got into the cylinders to cause that?</TD></TR></TABLE>
I'm not sure what caused it as I haven't pulled the pistons out to fully inspect it. I had to put the car back together the way it is as I need a winter car. The only thing I could think of is when I installed the piston rings, I may have ended up installing that one upside down instead. I was also running a supercharger on it and may have sucked up some small rock or metal.
guy_from_nerk
07-28-2013 12:25 PM
