Trailing Arm Removal
I have some bad wheel brearings in the rear of my Del Sol. I would like to swap them out with the entire Integra trailing arms, but I know there is a cable back there (e-brake cable) that I have no idea how to disconnect.
I've searched and found nothing that helped. Does anyone have a picture or anything?
Re: (93eg2james)
Under the center console where the e-brake handle is where you disconnect it. That part is pretty self-explanitory. Then under the car you have to unbolt a few clamps that hold the cables in place. It's not that difficult. The hardest part is getting the new cables back into the e-brake part.
Re: Trailing Arm Removal (93eg2james)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93eg2james »</TD></TR><TR><TD CLASS="quote">I have some bad wheel brearings in the rear of my Del Sol. I would like to swap them out with the entire Integra trailing arms, but I know there is a cable back there (e-brake cable) that I have no idea how to disconnect.
I've searched and found nothing that helped. Does anyone have a picture or anything?</TD></TR></TABLE>
Why do you want to swap out the complete trailing arm? Are you upgrading to rear discs with the Integra setup? If so, make sure you get the Integra e-brake cables as well.
Replace the rear wheel bearing is simple. Very simple if you have drum brakes in the rear. They are a sealed unit that comes out with the removal of the spindle bolt.
m-
m-
Re: Trailing Arm Removal (Mario_D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario_D »</TD></TR><TR><TD CLASS="quote">
m-</TD></TR></TABLE>
He has an EG2 = Del Sol VTEC. And he can't use Integra ebrake cables.
1sikhatch
07-16-2009 03:06 AM
tekstyle
12-10-2007 01:40 AM
philosofy1
05-31-2007 04:07 PM
