transmission trouble..
ok i have a 94 dx hatch..manual....for some reason now it is starting to become a problem..it is getting harder to throw the Gear in place..going into 1st is hard and switching to 3rd especially..what is the problem..THANKS
Re: transmission trouble.. (305accord)
try changing out yout taransmission fluid first and see how it is. even though my manual was feeling ok(its my first manual car) i changed the fluid out since i keep up with the maintenance and i felt a difference so maybe that will help you out
if you dont know how to do this, here is a writeup i did a while ago that helped a few people out
https://honda-tech.com/zerothread?id=1687986
Re: transmission trouble.. (imadigitalgod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imadigitalgod »</TD></TR><TR><TD CLASS="quote">try changing out yout taransmission fluid first and see how it is. even though my manual was feeling ok(its my first manual car) i changed the fluid out since i keep up with the maintenance and i felt a difference so maybe that will help you out </TD></TR></TABLE>
yea change the fluids...if it still persist then most likely its your tranny bro...gotta get a new one or replace the synchros...i'd rather just replaced the entire tranny...my cousins y8 tranny did the same and soon 3rd and 2nd just gave out...he couldn't even go to gear...
Re: transmission trouble.. (bmoua)
last time my car did that, the clutch springs fell out and i had to replace the clutch. Make sure you have enough fluid in the reservoir and that there are no leaks and no air in the lines.
Re: transmission trouble.. (DeadEnd9009)
o ok ..well now evrything is going smooth but now my 4th gear wont go in..iam just going to switch out the tranny for a ex/si tranny..i would like to know is what is the best way to change the tranny? take out the whole motor and do it or can it be pulled of the motor from the car..with the motor mounts off?
imadigitalgod
187
04-23-2016 07:08 AM
professorman
01-23-2015 09:50 AM
