Internal axle seperation, how do I get it back in?
My friend and I were in the middl eof a B16 swap. on the drivers side next on the half shaft, we were installing the new Axle. Well, when we realized that we'd put the axle on the half shaft without fitting it between the damper fork, we began to pull it back out, so it wouldn't slide out (we did use grease) and in the process of pulling it out, the tri bearings inside the axle boot seperated. We've done some extensive seraching but cannot find the solution to our problem. So, is it possible to get those SOB's back in? Or what, if som how exactly? My ownly solutino would be to twist and turn the bastard until it locks back into place, but I've never actually had this problem come up, therefore I'm at a loss.
I'd appriceate some help with this matter...thanks!
I forgot more about hondas then you will ever know....
Location: hop,skip, and a jump from the city,, new friggin york, USA
1 Post
Re: Internal axle seperation, how do I get it back in? (DX94')
you need to remove the boot, put the assembly together, then reboot it. sorry.
had the same problem.
I didn't need to remove the boot to get it back in. But it did take ages of working to get it back together.
Just removing the boot to fix the problem is really the easiest solution.
Re: Internal axle seperation, how do I get it back in? (MonkeyPuzzle)
what they said just bite the bullet and pull it apart, sucks though it can be a bit of pita... good luck to ya though.
Re: Internal axle seperation, how do I get it back in? (Kista20)
Yea, we finally just decided to remove the boot and insert the bearings back into the casing. Deffinately a pain in the *** and a real lesson learner! Thanks anyways guys
DJ Analog Duck (V.A. Mix) - Eastern Duck Heads West (2001) - 01 - Eastern Duck Heads West.mp3 [192Kbps] (04:12)
LS94tegra
04-19-2008 11:59 AM
