Reverse is gone!!
Reverse is gone!!
Alright my tranny will not go into reverse! Took my car on a few hard runs through the twisties last night. After the end of my last run I tried to put the car in first and my tranny seemed to be locked. was having trouble getting it to any gear then after some struggling I finally got it into 2nd and after i got the car moving all gears seemed to shift fine. My tranny has always been a little notchy shifting through gears but after this I havnt been able to get the car in reverse. I changed my tranny fluid out for some penzoil syncromesh hoping this would solve the problem but still nothing.Was able to get it into reverse a couple times and once it even popped right out of reverse. Now I havnt been able to get it in reverse period. You guys think I bent my shift fork? I hope i dont need a new tranny!! any ideas?
Re: Reverse is gone!! (k_motor)
i dont think its my clutch. I can't physically shift into reverse at all. It's not like i can shift into reverse but cant get it to engage. All other gears shift and engage fine.
Re: Reverse is gone!! (Gmoney16)
recently i did my friends trans for the same reason.his shifter felt sloppy.instead of rebuilding he got a brand new usdm type r to replace it.i changed them out and as soon as i did no more sloppy shifter.does yours feel sloppy while in gear?
* B A N N E D *
Re: Reverse is gone!! (thehondaconnection)
linkage its got to be, if it feels sloppy and you replace the trans and still feels sloppy its the linkage man
lemme guess powershifting thorugh each turn for about 45 mins? haha
nah no powershifting just a lot of heel toe. Kinda slammed it into 2nd once on last run. so im thinking that was the problem.
* B A N N E D *
Re: (thehondaconnection)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehondaconnection »</TD></TR><TR><TD CLASS="quote">just put in another trans and call it a day!</TD></TR></TABLE>
you would make a great warranty technician
Re: (Gmoney16)
Well thats weird cause 5th and reverse are together. Like for example when my 5th gear syncros went out i couldnt get to reverse. So its probably something else happening. What trans is it? If its a D series PM Bense, he knows those like it grew on him.
Go Tigers!
Re: (Luserkid)
moral of the story = you're not going to know unless you take it off, and take it apart to take a look at it.
Think of it as trying to diagnose a car and fix it without popping the hood.
3 options
1. repair your transmission (it will cost more than a used one)
2. replace your transmission (it will cost a lot)
3. get a helms manual and learn to do it yourself. It's easy.
3 options
he could try checking the linkage and make sure the bushings are ok and tightening things up if anythings lose before putting the tranny on the bench.
Go Tigers!
Re: Reverse is gone!! (JeffBro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeffBro »</TD></TR><TR><TD CLASS="quote">he could try checking the linkage and make sure the bushings are ok and tightening things up if anythings lose before putting the tranny on the bench.</TD></TR></TABLE>
it's not the linkage
