broken door lock help
I recently bought a '92 si and both doors only lock with the key from the outside, the inside levers are broken. is this a common problem, and what do i need to fix it?
Re: broken door lock help (jamesc2123)
Go here, put your info in and look up the part you need, then replace it......http://www.hondaautomotiveparts.com/
cute little bastard
the little piece on the "lock switch" probably snapped. happened to me also. I went to the junkyard and pulled a bunch out of Civics.
Re: broken door lock help (SkoundrelUSA)
If it is broken sad to say but you will have to buy the inner handle assy from honda at around 75 i think. Best place to look is the junk yard. good luck some yards will only sell comp. doors and not parts off them
WhiteOnRice
04-27-2010 01:19 PM
