OBD2b to OBD1
New User
OBD2b to OBD1
I was wondering exactly what needs to be done to run a obd1 motor in a obd2b car? i know you need the ecu a jumper harness and the distributor repinned. But there must be more cause my car won't start. It's a 99 civic dx with a JDM 94-95 B18C in it. I've got the complete swap from hmotors so i should have everything. Any help would be appreciated.
Go Tigers!
use your d16y7 harness. You'll need to wire in vtec, IAB (or just wire it with vtec) and possibly a knock sensor.
your b18c dizzy will need to converted to obd1. then you'll use an obd1 ecu with a obd2b->obd1 jumper harness
Re: OBD2b to OBD1 (simonsays)
don't repain anything just get and odb 2 distributer and your good. but the vtec you defeatnetly you have to wire that up and knock sensor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simonsays »</TD></TR><TR><TD CLASS="quote">I was wondering exactly what needs to be done to run a obd1 motor in a obd2b car? i know you need the ecu a jumper harness and the distributor repinned. But there must be more cause my car won't start. It's a 99 civic dx with a JDM 94-95 B18C in it. I've got the complete swap from hmotors so i should have everything. Any help would be appreciated. </TD></TR></TABLE>
you need a 99-00 SI rear and timing side motor mount
use your stock harness and modify it.. change from 3 wire iacv to 2, and add vtec, knock and IAB. its all simple.. or find a 99-00 SI harness or 99-00 EX harness for a direct plug and play(may need to extend a few wires)
you will need obd2 injectors and alternator if you want it to plug and play... you can use the obd1 distributor if you re pin it or find a obd2 one
jumper harness and a obd1 p72 ecu
New User
cool guys yeah i'm running a 99 si harness and a jumper harness from h motors if i use a obd2 dizzy do i have to repin anything? cause h motors said i couldn't do this, also about the alternator i just switched the connectors on the harness's so it would plug in is this wrong? thanks for the help guys
Re: (gabebauman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabebauman »</TD></TR><TR><TD CLASS="quote">Maybe it's because your knock sensor isn't hooked up. </TD></TR></TABLE>
The car will run, and drive without a knock sensor.
Re: (my_slow_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my_slow_civic »</TD></TR><TR><TD CLASS="quote">The car will run, and drive without a knock sensor.</TD></TR></TABLE>
Ok...well that solves that...thank you.
slammedz6ef
12-31-2007 04:13 AM
robbizza
05-20-2006 05:53 PM
alexsracing
11-14-2004 01:37 PM
KevronsEG
12
11-18-2002 07:57 PM
