d16z6 valve adjustments/specs
I recently purchased a new d16z6 head for my boost application...the seller said that the valves needs to be adjusted...So i was wondering if anyone knows a site i can look valve adjusting up on bc ive never did it before...i know you have to use feeler gaugses...but im not exactly sure on how to adjust them...Thanks guys
Re: d16z6 valve adjustments/specs (JDM-SI Sol)
check you pm. download the eg file . look under the engine section, then read. you shouldnt have any other questions about your engine.
Re: d16z6 valve adjustments/specs (92ehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92ehatch »</TD></TR><TR><TD CLASS="quote">.008-.010 intake
.009-.011 exhaust</TD></TR></TABLE>
You should confirm your information before you throw it out there...
The correct spec per the Helm is as follows:
.007-.009 (intake)
.009-.011 (exhaust)
.007-.009 (intake)
.009-.011 (exhaust)
Re: d16z6 valve adjustments/specs (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">You should confirm your information before you throw it out there...
.007-.009 (intake)
.009-.011 (exhaust)</TD></TR></TABLE>
oh ****...you are right!!!
i was going off memory..
editing first reply...
.007-.009 (intake)
