Heater Problems
Heater Problems
Hear is my problem. My heater does not work when i'm idleing. When i start to drive it works fine. I change thermo with oem. I changed radiator. It only works when i start driving but does not work while i'm idleing. Also when i'm crusing say about 60 and i put it in nuetral the rpm jump up and down from like 1000-1300 three times them when i come to a complete stop it goes down to five hundered the back up toe 1100 finally stopping at 900 i changed pcv vavle know it does not do it all the time just some time tell me my problems guys
EACV/IACV could be the roots of the idle problem, btu could also be indicator of bad thermo sender, low coolant, air pockets etc. A broken water pump could possibly not be pumping enough water at idle. Could be a clogged heater core, but not really since you get heat when moving. Or a weak blower motor?
entityzero
03-26-2007 07:44 PM
homeskillet
12-24-2004 09:22 PM
-[95cxhatch]-
02-28-2004 08:20 AM
