EK 97 hatch GSR swap
i posted this in the hybriid section as well just in case . hey guys i need some help i have a JDM GSR or whatever it is called in japan (SiR-g i think) anyways that is not the point of this post. my question is this: can i buy a OBD2 GSR wire harness and plug and play with my car basically. now iam not refering to the ECU just the engine wire harness. i appriciate all the help thanks...
Re: EK 97 hatch GSR swap (backagainracer)
no you cant. the gsr wirring harness is like a 92-95 civic. it will not work. probly the easiest thing to do is get a usdm b16 harness wire the second intake sensor and than get a obd1 to obd2 conversion harness. your civic wirring harness is one peice the gsr is 2.
Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 »</TD></TR><TR><TD CLASS="quote">ya u can use a b16 harness or just use ur stock d series harness and modify that for the gsr</TD></TR></TABLE>
Correct, OR he can also get a US GSR/ITR harness and it'll plug right in. Only thing. It's just depending on what year his EG & what ecu he uses whether he has to wire vtec/knock sensor through the chassis subharness.
If you use the GSR ecu, you will need to wire those from the chassis subharness (passenger shock tower) to the ECU.
Re: (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">
If you use the GSR ecu, you will need to wire those from the chassis subharness (passenger shock tower) to the ECU.</TD></TR></TABLE>
he said it was a ek so that wont work
Re: (onephatcivic98)
ColinSiR
05-11-2008 12:19 PM
562daybid
03-23-2008 06:29 PM
eknorcal
11-14-2005 10:23 PM
