hard ilde
hard ilde
When im at ilde the car kind of shakes.. its around 800-900rpm if i get it to 1000 it stops how do u turn the idle up 1999 civic si gsr swap "9k miles"
Re: hard ilde (CivicGSRsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicGSRsi »</TD></TR><TR><TD CLASS="quote">When im at ilde the car kind of shakes.. its around 800-900rpm if i get it to 1000 it stops how do u turn the idle up 1999 civic si gsr swap "9k miles"</TD></TR></TABLE>
WTF are you talking about. My H22 idles at like 300 rpms. Why do you need your car to idle above 1000 rpms? You'd need to adjust your throttle cable, or maybe your IACV is messed up.
Re: hard ilde (O RLY)
yea i agree withe him, dont adjust your idle up just to take care of a missfire. Thats why your motor shakes, because its not running correctly. It should idle around 500-700 rpm smotthly. Even 300 is messed up unless you have a radical cam? HOw many miles on the vehicle?
Re: hard ilde (Amped)
9k is on the egain... but i have a volt meter there in front on the tak so its hard to see b/c i have 4 points so maybe its around 5-7 rpm
wel either way you have a missfire, thats why its shaking. So now you have to determine why it has a missfire. Thats diffficult to determine over the internet.
might be a good idea, header or intake shouldnt cause a check light enless you left the o2 out or forgot something stupid.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicGSRsi »</TD></TR><TR><TD CLASS="quote">the check engein light is on but i hought it was b/c of my hks and headers and intake... i get it checked out </TD></TR></TABLE>
Let us know what code it sends.
I have your solution
i have a 99 si with a gsr swap 2,i experimentnted with the throttle body beause the usual idle was 1-1.5k...i tightning the bolt and fixed the problem, hope it helps
Paprika
05-08-2007 03:18 PM
hatchfreak92
10-17-2004 08:59 PM
