NEED HELP! car will not start
my car does not do anything when i turn the key to the start posistion ....all lights and everything wokrs... got starter checked and thats fine... i have plenty of power to the start from the battary ... but it does nothing when i turn key to start it
Re: NEED HELP! car will not start (cbstudd77)
To start, I would first check all fuses, making sure they are the correct amperage..
Then move onto trying to swap the main relay. Does the fuel pump prime at all?
Also make sure the battery has a FULL charge.
Keep us updated.
Keep us updated.
Re: NEED HELP! car will not start (dr92cx)
start (remote wire ) that signals the starter.....check that i ran it from the starter to the ignition and it didnt look bad but it fixed the problem
Re: NEED HELP! car will not start (cviccoupe)
grounds! check ur ground wires, actually discconect them clean them and then hook em back up. on the battery and the frame
ok i did this other day, and this fixed my car. i came out of the gas station after driving 30 min. to work and my car would acknowledge that i had the key ready to turn the motor over and when i went to turn it over it would not do anything. so if you car is not turning over it you should try this!!! try to push start the car in third if it is a manual tranny. if it push starts here is the fix: you have to take a look at your starter/clutch interlock switch. its located under your dash, drivers side, above the clutch pedal.make sure that when you push the clutch down that it is depressing that switch. you can do it manually with your finger.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cbstudd77 »</TD></TR><TR><TD CLASS="quote">thanx for the help it was a ground wire that was a lil dirty ... </TD></TR></TABLE>
ALWAYS THE GROUNDS! I ONLY BEEN A MEMBER SINCE NOV. AND THIS IS LIKE THE 4TH TIME IT WAS THE GROUNDS
ILUVTEC
03-20-2010 01:31 PM
